2000 S-Type center dash pocket
I'm having an issue with the spring loaded pocket that is next to the radio. If I push in on it to release it, it flys out of the dash. I can see a small slit on eiither side of the pocket where it looks like a plastic or rubber stopper should sit that would keep the pocket from completely popping out. If someone knows how to remove them, could someone please take a picture of these parts so I know what I'm looking for? I'm sure I would have to buy a new pocket if I wanted the factory parts, but I think I might be able to fabricate something to work if I knew what they looked like. Thanks in advance.
There is a little latch on top of that cubby box that holds it closed. Usually the latch pops out. You can pop it back in. You have to remove the radio, cubby box, and climate control display as one unit and you'll see where the latch goes on top of the box. It's probably just laying there somewhere.
jagconvert (03-31-2013)
RaceDiagnostics
09-13-2015 02:22 AM
1964Daimler
09-09-2015 11:28 AM
