2000 s type check engine light
Old 02-21-2008 | 11:10 PM
FactoryJaguarTech's Avatar
Default RE: 2000 s type check engine light
Take it to autozone. Get codes read then clear light. Let is know what the codes are.
Old 02-24-2008 | 12:18 AM
Cylinder 3 misfire is the P0303 code. I would look at ignition coil before anything else. If your coils have yellow/green labels on top they are old coils and I would replace them all. You didnt state how many mile on your vehicle, but plugs are 100k and normally last that long. Coils are know issue and there are no wires as in conventional cap and rotor vehicle.
Unfortunately Cyl 3 is on the passenger side of the engine rear most cylinder which means removing the intake manifold to get to it. However on the bright side, while you are there, you should replace the lower breather hose. Your car will run far better after these repairs are made.
Hope this helps.
Old 02-24-2008 | 10:12 AM
jag_genius's Avatar
he dint say if it was V6 or V8 .. but V6 is a good guess.lol
Old 02-24-2008 | 11:26 AM
LOL....always gotta look at the money factor first
Old 02-24-2008 | 05:51 PM
Doesn't change the fact that it is more than likely a coil issue.
The fuel smell however may.
You smell it from the exhaust? From sitting in drivers seat? Head under the hood?
Old 02-24-2008 | 09:21 PM
jag_genius's Avatar
you better get fixed soon or by by cat. $$
Old 02-24-2008 | 09:43 PM
unless under 8/80. Still $$$ for us LOL
Old 02-25-2008 | 08:30 PM
I do not. But I know it is around $13.00
Just call the dealer and ask for the part number.
Old 02-28-2008 | 08:30 PM
If the car hasnt had synthetic in there, I have heard bad things about starting car on synthetic when mileage is up there. Better to use a heavier weight oil.
BrentGardner
28
04-26-2024 04:08 AM
MJ'S Jag
11-10-2022 09:14 AM
stanjag
08-30-2015 11:35 AM
nelsonht
08-30-2015 07:01 AM
peterg19
08-28-2015 09:42 AM
