2000 S-Type V8 Purchase Help
Guest
Posts: n/a
Im in the marketfor a new car and i been doing some research and i was considering a 2000 Jaguar S-Type V8.
I reall admire the car but i tried to do research on the car and for some reason i cant find anything so i was wondering if you can help me seeing as im a new member =)
whats the 0-60 in the V8 S-Type and its quatermile
Is it a bad Purchase like should i even bother
Pretty much what i ask is if you can tell me anything and everything about the S-Type V8
Because I cant find find anything
So thank you in advance for your input
ORIGINAL: FactoryJaguarTech
I would have to say that your query on the 1/4 mile time and 0-60 time indicates you may be wanting to punch it frequently.
I have my doubts as to how well the trans will hold up.
Save a little longer and get a 2003 with the 4.2 v8 and ZF trans.
Guest
Posts: n/a
ORIGINAL: Soccer6planer
go newer i have a 2000 S-type v8 and its been nothing but trouble. Coil packs, window regulator, engine misfire, idle control module, freak "limp mode" episodes. But it does look good for sure and is a hell of a car when it feel like acting right
Here's my maintanence schedule.
Oil change every 5K with syn oil and Purolator filter
Fuel system cleaner every 5K just before oil change
Transmission fluid drain and refil every other oil change (full pan drop with filter replacement every other time I do this so about 20K miles)
Rear end fluid chang every other oil change (not the same one as the trans)
Air and cabin filters every January and June (dusty conditions here)
Pull and inspect plugs and coils every Jan and June replace if necesary
Radiator flush and fill every June
Inspect and grease window regualtors, sunroof, and door hingesevery oil change
Its a lot of work including all the cleaning/ waxing and leather care stuff also, but it's worth it to save on big costs (I've seen outrageous quotes on here for all of this stuff). I do all of this myself, because I take alot of pride in my nice rides (wife has a cadillac that I do the same regimen on), and I don't want to shell out thousands every year in basic maintenance costs.
ohsigmachi, your car is one of the few. You said that a rebuilt 5r55n is 1400. A ZF is more. However, how many times do you think that Ford trans would have to be rebuilt while it is being raced constantly. They are not a good trans for hard driving. The ZF is in all of the rear wheel drive jags from 2003 on, except the XJ, 2004 on. It is very durable if they are driven. The harder the ZF is driven, the better it seems to be. I worked on a forum members car the other day.....over 100k on a 03 STR. Transmission is still the original. I reflashed it because of the lurch......gave instructions on how to do drive cycle....and he states it shifts well again.
I would take the ZF any day over the Ford.....even if it was 10 times the cost to replace. 90% of the ZF trans that were replaced, did not need it. People not fixing them properly. So my point still stands. Where choice comes in, I would get a 2003 S with ZF. STR preferably.
i have a 2000 s type 4.0 i love the look of the car and everythign about it but it has also given me alot of problems. im 19 so this is a hard car to take car of i have had it for almost a year and i put over 3 thousand into it between power steering pump coils spark plugs misfire and the worse problem is the transmission slips anytime it wants to and takes a delay to go into drive or reverse sometimes 30 seconds.so i would suggest not to get this car unless money isnt a issue for you but othersie i would defintly suggest to get anewer one.
Guest
Posts: n/a
I have just bought my 1999 Jaguar S-Type and it has 118,000 miles (185,000 km)
It is on the original gearbox and it is running perfectly (I work in a Garage so had it checked over by a real Master)
Maybe the car has had a very easy life and that is why
For me I didnt buy it for speed I just bought it because I thinkl it is a really gracefull looking car and the main reason is that there aint that many around.
I have bought it as a second car so I wont drive it every day
Not sure how it would be if it was my only car but I have to say I love it.
I plan to keep it and just use it from time to time.
Maybe I should go easy on the gearbox so I dont have to face the problem that a lot of guys do on this forum ?
ORIGINAL: whitestype
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
060, 2000, 5r55n, cost, costs, ford, jaguar, maintaince, maintenance, reliability, review, silver, stype, transmission, type, v8
