2000 s type wont start
Howdy,
Am a member of other makes of cars but , just got this JAG 2000 s type V8 and it is sitting in my friends garage and it was running just fine. Sitting for about a month and now it turns over, but will not start. Put scanner on and got a P0001 code that says fuel volume regulator open. Fuel inertia switched is depressed and checked all fuses. Big help needed please.
Received 2,682 Likes
bcampbel (01-05-2014)
This should help you with your no start issue
Gus, thanks so much. This solved my problem. I had charged the battery all night and the engibe turned over strong so I assumed the battery was good. When I read the link you sent it talked about how the jaguar is sensitive to the actual voltage so I jumped it with my jeep. Started right up. Need to replace the battery. Thanks again.
Gus (01-05-2014)
1964Daimler
09-02-2015 11:41 PM
stanjag
08-30-2015 10:35 AM
