2000 v8 Starter rebuild parts?
So being cheap on parts, and from an era where your repair instead of replace (read OLD!), I thought I would pop my starter out and see why it's a 50/50 shot on starting, thought it may be extended electrical but the solenoid made the right sounds, jumping it from another car or charging the battery fully meant it started. But there was never an in-between, like the starter dragging. Turns out the copper contacts from the plunger are worn, one wafer thin on an angle, I cleaned it and realigned the contacts and I am about to put it back together but a coffee break had me looking for a replacement just in case this does not work. The plunger is a common part but does anyone in the trade know if the solenoids are also the same, at least the contacts as I'm sure it would be a cheaper avenue to go down. Here's the list I got for the plunger
JAGUAR Car & Lt Trk
TOYOTA Car & Lt Trk
CHRYSLER
56027703AB, 56027703AC, 56027703AD, R6027703AC
Plunger for Denso 1.2KW & 1.4KW OSGR Starters
Part Numbers
NIPPONDENSO
053660-7150, 053660-7151
Applications
DODGE Car & Lt Trk
RAM PICKUPS 8.0L(488) V10 1999-2003
JAGUAR Car & Lt Trk
S-TYPE 4.0L 2000
VANDEN PLAS 4.0L 1998-2000
XJ8 4.0L 1998-2000
XJR 4.0L 1998-2000
XK8 4.0L 1997-2000
XKR 4.0L 2000
XJ8 4.0L 1998-2000
XJR 4.0L 1998-2000
XK8 4.0L 1997-2000
XKR 4.0L 2000
TOYOTA Car & Lt Trk
CAMRY 2.2L 1998-2001
RAV4 2.0L 2001-2003
RAV4 2.4L 2004-2005
RAV4 2.0L 2001-2003
RAV4 2.4L 2004-2005
CHRYSLER
DENSO FIRST TIME FIT
280-0378
280-0378
FORD
96JV-11001-AC
96JV-11001-AC
JAGUAR
LCA-1850AB
LCA-1850AB
NIPPONDENSO
128000-8430, 128000-8431, 228000-5090, 228000-5091, 228000-5093, 228000-6270, 228000-6271, 228000-6272, 228000-6273, 228000-7430, 228000-7432, 428000-0990, 5-228000-079
TOYOTA
28100-74270
as you can see it's a common enough part!
28100-74270
plums (03-26-2013)
Applications
AC Delco
323-1051, 336-1428, 336-1541, 336-1568, 336-1573, 336-1624, 336-1628, 336-1633
Acura
31200-P54-003, 31200-P72-A01, 31200-P73-A01, 31200-P75-901, 31200-PR7-J01, DX51D, DXD1V, DXD1W, DXDR6, DXDRJ
Carrier Transicold
29-39135-00
Chrysler
04609346AD, 4467185, 4557284, 4609010, 4609346AD, 4609703, 4686104, 4686111, 5234648, 53005984, 56004757, 56027702, 56027703
Cummins
3675153RX
General Motors
94854717, 94855154
Honda
06312-P03-901RM, 31200-P03-901, 31200-P03-904, 31200-P54-003, 31200-P73-A01, 31200-PM3-J01, 31200-PM3-J02, DX4R4, DX4RE, DXDR6, DXDR7, DXDRJ
Isuzu
2911230000, 8943446930, 8943718330, 8943718331, 8943770240
Kubota
19013-63012, 19013-63013
Nippondenso (Denso)
128000-7010, 128000-7390, 128000-7500, 128000-7560, 128000-7710, 128000-7712, 128000-7713, 128000-7714, 128000-7715, 128000-7810, 128000-8030, 128000-8031, 128000-8350, 128000-8360, 128000-8400, 128000-8410, 128000-9710, 128000-9720, 128000-9730, 128000-9740, 128000-9750, 128000-9751, 128000-9752, 128000-9870, 228000-0360, 228000-0361, 228000-0363, 228000-0820, 228000-0821, 228000-0822, 228000-0823, 228000-0830, 228000-0831, 228000-0832, 228000-0833, 228000-0890, 228000-0900, 228000-0901, 228000-0902, 228000-1070, 228000-1071, 228000-1560, 228000-1700, 228000-1800, 228000-2050, 228000-2060, 228000-2061, 228000-2062, 228000-2500, 228000-2890, 228000-2940, 228000-2960, 228000-3010, 228000-3011, 228000-3012, 228000-3013, 228000-3014, 228000-3020, 228000-3021, 228000-3023, 228000-3024, 228000-3030, 228000-3032, 228000-3033, 228000-3210, 228000-3211, 228000-3260, 228000-3390, 228000-3391, 228000-3392, 228000-3393, 228000-3400, 228000-3401, 228000-3402, 228000-3403, 228000-3990, 228000-3991, 228000-3992, 228000-4000, 228000-4001, 228000-4370, 228000-4371, 228000-4372, 228000-4390, 228000-4391, 228000-4650, 228000-4651, 228000-5490, 228000-5670, 228000-5680, 228000-6170, 228000-6172, 228000-6173, 228000-6280, 228000-6281, 228000-6282, 228000-6283, 228000-7200, 228000-7201, 228000-7250, 228000-7260, 228000-7261, 428000-1550
Toyota
28100-01030, 28100-02050, 28100-02060, 28100-03020, 28100-03030, 28100-03070, 28100-03090, 28100-03100, 28100-08020, 28100-16130, 28100-16180, 28100-16220, 28100-16240, 28100-16270, 28100-20553-71, 28100-35060, 28100-35060-84, 28100-35090, 28100-64170, 28100-66040, 28100-66060, 28100-74070, 28100-74090, 28100-74100, 28100-74130, 28100-74140, 28100-74230, 28100-74240, 28100-74260, 28100-74280, 28100-74290, 28100-74291, 28300-22003-71
AC Delco
Acura
Carrier Transicold
29-39135-00
Chrysler
Cummins
3675153RX
General Motors
94854717, 94855154
Honda
Isuzu
Kubota
Nippondenso (Denso)
Toyota
exjay8 (10-24-2019)
Wes Steenrod
09-06-2015 06:52 PM
