2001 S Series wont turn over
Hello- first time posting, hoping you guys can help me.
I had some fault codes read today, after the car would not turn over. Since the battery was weak I decided it would be a good time to change it our. When I change out the battery the alarm went off, I was not able to hit the key Fob to get it to stop, but instead needed to put the key in the ignition. Sadly we had the same problem with the new battery. The lights come on but the car will not turn over. Feels like an anti theft issue but can't make it go.
Some things I tried:
Locked and unlocked doors with FOB
Turn on and off the panic with the FOB
Cycled the gears
NO LUCK PLEASE HELP!
Cycled the gears
Welcome to the forum Gora1ders,
I've moved your question from General Tech Help section to S-Type section. Members here with the same model as you have will be able to help. You should add details of the actual codes for the best advice.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Update
I have gone back to the car. I am able to use the Key fob to make the alarm light turn off. I checked the fuse in the passenger area for starter relay. I disconnected the battery for 30min and checked voltage at the battery and the fuse box in the trunk. When I connected the battery I was able to see the alarm light blinking, I then used the FOB to turn it off, still the same problem of not turning over.
Everything else seems to be working, dash lights, steering adjustment, windows, lights, radio, and heater fan.
Any other help would be great!
If this should happen again - when you turn the ignition key to "run" - make sure the "P" is illuminated on the shifter - if not, shift to "N" - then start the car.
