2001 S Type 4.0 Timing Chains R&I per JTIS FAQ
Old 03-22-2012, 08:13 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Default 2001 S Type 4.0 Timing Chains R&I per JTIS FAQ
Hi
I know there is a great DIY for Timing Chains already posted here on the S Type section of the forum.
But, it might be helpful to have the JTIS instructions as just another source of step by step illustrations and instructions.
I created these 17 pdf files that covers all the components that the JTIS manual spells out:
2001 S Type V8 Secondary Timing Chain LH R&I.pdf
2001 S Type V8 Secondary Timing Chain RH R&I.pdf
2001 S Type V8 Primary Timing Chain LH R&I.pdf
2001 S Type V8 Primary Timing Chain RH R&I.pdf
2001 S Type V8 Engine Front Cover R&I.pdf
2001 S Type V8 Cramkshaft Pulley R&I.pdf
2001 S Type V8 Accessory Drive Belt R&I.pdf
2001 S Type V8 Valve Cover LH R&I.pdf
2001 S Type V8 Valve Cover RH R&I.pdf
2001 S Type V8 Generator R&I.pdf
2001 S Type V8 Oil Cooler R&I.pdf
2001 S Type V8 Cooling System Draining - Filling & Bleeding R&I.pdf
2001 S Type V8 Air Cleaner Outlet Pipe R&I.pdf
2001 S Type V8 Air Cleaner Element R&I.pdf
2001 S Type V8 Ignition Coil-on-Plug R&I.pdf
2001 S Type V8 Evporative Emission Canister Purge Valve R&I.pdf
2001 S Type V8 Throttle Body R&I.pdf
Hope this helps
Jim Lombardi
Last edited by jimlombardi; 08-02-2013 at 03:55 PM. Reason: replace 1999 XJ valve cover info with 2001 S type info
The following 4 users liked this post by jimlombardi:
joycesjag (03-23-2012), mrkinsly (11-05-2012), semmesg (09-13-2016), thebiglad (08-02-2013)
Old 03-22-2012, 08:21 PM
Received 9,010 Likes on 4,113 Posts
Added to the FAQ Jim.....
lobsterD90
11-12-2022 09:51 PM
xjrjag
10-27-2021 11:48 PM
celticpiping
09-18-2015 06:17 PM
Bcrary3
09-12-2015 08:43 AM
souldoubt
08-25-2015 08:15 PM
Quick Reply: 2001 S Type 4.0 Timing Chains R&I per JTIS FAQ
