2001 S type p0307 and long crank
Have a #7 cylinder misfire code after new coil and plug replacement. Car was driven about 2000 miles after these parts were put on before the light came on again for cylinder 7. Looking at freeze frame info it says it only happened 1 time at 1800 rpm and set the light. Also sometimes it seems to crank about 10 seconds before starting cold but not always. Put a fuel pressure gauage on it and the fuel pressure bleeds away to 0 after about 20 minites but comes right up when starting. Could the injectors be leaking down when not running. It does seem to smoke some when starting cold like raw fuel??????
stanjag
08-30-2015 10:35 AM
