2001 S Type V8 4.0 Timing
hi all,
i bought a 2001 S-Type from a friend that got frustrated with the mechanics in his area not being able to set the timing after it jumped timing.
they did not have the proper tools in the beginning therefore i'm assuming they did not lock the cams prior to trying to time it.
i now have all the tools to do the job but i have questions:
is there a way to set the timing if the cams have been moved previously as i suspect?
on my other vehicles there were timing marks however i'm hearing there are none on the Jaguar.
if anyone knows any tricks to set the timing it will be greatly appreciated or am i better of investing in a used engine, locking the cams and changing the problematic plastic tensioners.
thanks!
thanks!
Received 6,355 Likes
Welcome to the forum,
No tricks the whole procedure is detailed in JTIS which is a free download from the forum.
Are you sure there was no damage when the timing jumped?
Don't forget to post your intro in the new members section.
i guess i will know when i pull the head.
Have you changed all the primary, secondary tensioners and all the timing chains?
If not you are wasting your time.
Understand that jumping time is the least of your problems. You probably have bent valves or worse.
Let us know what you find. Get the shop manual which is called the JTIS. We have it free on this forum. Look at the top of the forum for JTIS.
If you lock the crank with the tool in the torque converter drive plate, you can turn any cam to anywhere you want. The pistons will be DOWN enough in any cylinder so as to NOT contact a valve!!!!!
Then rotate the cams to the 'timed' position and lock the sprocket fasteners down tight.
If the cams are already disconnected from the chains, you can loosen the cam caps to lift the cams enough to close the valves. THEN rotate the crank!! (many ways to 'skin-the-cat')
bob gauff
bob gauff
Strokeman (02-22-2015)
Received 2,677 Likes
at this point i think the use engine is the best way to go however i will want to change the tensioners before installing the replacement engine.
the mechanic said it did but i dont have much faith in the mechanics here. i may have to take it to the Jaguar Dealer which i'll have to put the car on a ferry to get it to them or simply buy a use engine as i was planning to do when i bought the car. at this point i think the use engine is the best way to go however i will want to change the tensioners before installing the replacement engine.
NBCat (02-22-2015)
I bought a Jag (1999 XJ8) with a broken secondary timing chain and replaced all the chains, tensioners, guides, etc.
I finished up and made sure the battery was fully charged. I cranked it and IT WAS SLOW!!!!!!!!!!!
It turned out that the starter was 'burned-up' trying to start the broken engine!!!!!!!!!!!!!
I installed a good-used starter that I had on hand and the engine fired right up!!!!
Just make sure you are not misdiagnosing faults and headed in the wrong direction.
Check the current draw of the starter. I had a draw over 500 amps with the faulty starter.
Probably the engine but...............
bob gauff
bob gauff
update:
after opening the engine there were so much damage that it was best to replace the engine which i did.
i changed the alternator however it was an aftermarket alternator which works but causes the battery light to intermediately come on. i will be replacing with OEM soon.
The car ran pretty good for few hrs; had a P0340 Camshaft position senor A circuit (bank 1 or Single Sensor) code but it started and ran good.
took it out yesterday and experienced power loss; its intermediate, it runs rough with little to no power for a few than it will run fine for a few and repeat this.
now i'm getting 2 CODES:
P0357 Ignition Coil G Primary/Secondary circuit
anyone experienced this or knows how to fix it?
thanks!
thanks!
i do not believe this engine had a timing job done on it.
i looked at the sensor and on my Santa Fe it was easy to change the cam sensors, there was a bold right on the sensor. i don't see it on these ones, do i have to lift the cover to change the cam sensors in the S-Type v8 4.0?
i will go to the yard and look on the old engine for the sensors tomorrow.
update:
i ordered a new Engine Camshaft Position Sensor.
Position: Right
Terminal Gender: Female
Took off the right valve cover to replace the sensor and it had a male gender Terminal Sensor.
I found out it’s a:
Engine Camshaft Position Sensor Right Standard fits 98-03 Jaguar XJ8 4.0L-V8
i don't know what’s going on, however there was a break in the wire which i figured must have caused the code in the first place. I repaired the broken wire and put the old Sensor back in (because the new one had Female Terminal). that did not solve my problem.
I don’t recall my replacement engine coming with harness and I asked the mechanic if he made any modifications to my harness, obviously he said he did not. i don't know what’s going on, its driving me crazy.
this is my only option, the mechanics here are useless and the previous owner had too many different guys working on the old engine which is why i bought a replacement after buying the car.
this is what came out of the replacement engine.<br/>as you can see, Male gender Terminal
these are the 2 from the previous engine that the mechanic gave me along with the 1 i ordered.<br/>both Female gender Terminal
