2001 S-Type won't crank - it's hot out here!
Old 08-08-2012 | 12:25 PM
sjwalk's Avatar
Default 2001 S-Type won't crank - it's hot out here!
It has been over 100 degrees here (over and above 110) for over 3 weeks. Recently my 2001 S-Type 4.0 V8 has failed to start when left in the heat. I will drive for awhile without issue, but as soon as I turn the car off - nothing on restart. All the lights and bells and whistles work (radio, etc.). I have a one year old battery that I just had checked - charge is great. If I wait about an hour (up to as long as 3), the temperature gauge will go from normal to 1/4 (cold), then the car will start. Has anyone ever seen this before?
Old 08-08-2012 | 12:47 PM
Mikey's Avatar
Sounds like a weak starter solenoid or very high resistance in the wiring. Check all the grounds and connections as a first step.
Old 08-08-2012 | 03:21 PM
abonano's Avatar
+1 on Mikey's response - heat soak (starter solenoid) or starter is on it's way out. Be prepared - the starter is underneath the intake manifold and is only accessible from the top of the vehicle. (I stand corrected - I was under my S Type last night and the starter seems accessible from beneath the vehicle)
Last edited by abonano; 08-09-2012 at 09:31 AM. Reason: correction after posting orig response
Dagny
06-11-2024 02:06 PM
Bcrary3
02-21-2023 05:29 AM
Sprayall
05-30-2021 09:13 AM
Doovoe
XJ40 ( XJ81 )
09-06-2015 11:54 AM
Sprayall
09-03-2015 08:49 PM
Quick Reply: 2001 S-Type won't crank - it's hot out here!
