2001 stype 4.0 throttle issue
Finally got the issues fixed after all the reading of posts and all the wiring schematics I've researched on JTIS. It turned out to be as simple as a fuse was in the wrong location. I looked at it at least ten times im sure, but what i found was in the manual it said the fuse location wasn't used but sure enough it was. The one next to it wasn't used so i just switched them and bingo she has a pedal and runs.
Just has a little miss that im sure is from not running right and needs to run for a while to clear up also still got a p0341 fault but since i fixed the fuse problem i havent cleared the codes so it may be a lingering code. I did notice when i pulled the cps it had some damage to it. Once again thatnks to some good advice on the forums ive got a direction to move in. I need to change out the valve cover bolts above the cps. Going to clear codes and see where it goes from there.
yes sorry i bought the car with a new engine in it and whom ever tried to put the engine it in messed everything up. i am fixing everything that they touched what a pain. Well new issue it will start and run then all of a sudden just die with no codes or anything, i put fuel pressure gauge on it and it has fuel pressure even when it stalls but when it stalls it goes up to 60 psi. when it dies it just quits no sputtering or nothing just stops. Another hurdle with this car.
Which fuse did you replace???
which fuse?
which fuse did you find needing replacement?
my jag is 2001 3.0 S-type, fuse locations may not be the same, but you imput would be helpful.
I recently purchased 2001 3.0 S at auction, so just like you, I am working on a situation with no prior info imput.
Fuse: position number & fuse box location please.
Last edited by LAjag; 07-09-2017 at 03:05 PM. Reason: Which Fuse?? left off subject title info
