2001S-Type power drain & hesitation
Old 06-10-2008 | 08:48 PM
jag_genius's Avatar
Default RE: 2001S-Type power drain & hesitation
s type 's are fun to diag.. last 2 common ones ive had.. is check all the powers..for the front control module under dead pedal..(FEM) if one is missing or low due to power wire from right interior fuse box going thru the front harness.. and can get corroded.. one of the powers.. i think there are 3.. is a keep alive power.. 2nd.. Ignition barrel/switch.. worn out.. if he doesnt shut off the car all the way to left hardbefore taking the key out.. the accesorys can stay on.. ie radio.. .. if you need anymore ideas.. give me a PM
Old 06-10-2008 | 08:56 PM
ibjags's Avatar
definent ignition swith as a possiblity
the piece in the key is the key transponder
without it the key wont start the car
and the engine hesitation could be dead coil packs
need misfires read with genrad handheld scanner to verify
Old 06-11-2008 | 04:48 AM
FactoryJaguarTech's Avatar
Good old GDS510 and non continuous monitoring LOL
aholbro1
08-05-2021 05:02 AM
Scarecrow
03-28-2016 03:17 AM
Dan
09-17-2015 05:54 PM
chatmanx
09-11-2015 07:17 PM
AtholC
09-09-2015 09:07 PM
Quick Reply: 2001S-Type power drain & hesitation
