2002 Jag S Type 6 cylinder
Received 1,442 Likes
Hello David, and greetings from down under,
I am sure you know (but for the sake of others here also) the 2002 is little changed from the earlier cars in respect to body (interior and exterior), powertrain (including 5spd auto), suspension, brakes etc. Any differences will be minor and tend to be evolutionary, not revolutionary. The major facelift and all its improvements, appeared on the MY2003.
OK, so the major variance from your existing car is the V6 engine - but also the ECU/PCM program settings. Compared to the TC support and some bore wear issues of the early 4.0L V8s (of which I am sure you are aware and have checked to ensure your current car has the necessary replacements) the V6 was, IMHO, relatively trouble free from the outset.
That comment comes with the expected caveats. Remember that these engines, properly maintained (fluids. filters etc etc etc), are long lived . . . but, any engine that is poorly maintained is bound to be unreliable and, frankly, best avoided. Why? No oversized pistons, rings, bearings are available so badly worn bottom ends are most often discarded.
There will be those like [JagV8] who can give you a more detailed V6 overview, but I do think that you may be well served by searching past threads here to look for any fault patterns. I suspect that the major (very common) weakness for all these models is on items like battery maintenance, electricals, suspension bushes, wheel sensors etc (stuff common to your current S-Type) . . . and primarily, the really BIG one . . . owners who do not understand or carry out, preventative maintenance.
I know that doesn't include present company, does it?
Cheers,
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Ken
Cheers,
Ken
davidladewig (10-17-2016)
cat_as_trophy (10-17-2016),
Received 2,651 Likes
Most common issues I have come across with the pre-2002 3.0 litre models is the breather elbow under the lower inlet manifold, leaking cam cover gaskets and failure of the upper radiator hose at the bleed screw.
As mentioned above, the Ford Duratec 3.0 is a very well designed engine and can easily exceed two hundred thousand miles if maintained.
Grant Francis (10-17-2016)
Grant Francis (10-18-2016)
Hello again David,
Isn't it tough to walk away from what (initially) appears a bargain. I had a similar experience recently - late XJR, excellent interior, apparently good mechanicals and all electric/electronic thingies faultless (more later) and, as per owner's description "from 5 metres away, it looks stunning". One small problem . . . sooner or later, one must get closer than 5 metres away . . . and only then, realize that almost every panel (even the roof) had a small ding, scratch, scuff. Independent estimate placed all the panel repairs and complete respray at greater again than the asking price . . . resulting in a final investment greater than a blemish free example . . . and without all the bother.
Bother? Yes,y'see . . . IMHO, if an XJR body is allowed to descend into such an unloved state, what confidence do you have for all those mechanicals and electronics that first appeared OK?
I commend your wise decision to walk away . . . another, more suitable alternative will soon appear . . . perhaps a later "post facelift" model as a complement to your "pre". Believe me, they are sooooo nice!
Cheers,
Ken
Cheers,
Ken
davidladewig (10-19-2016)
I am working on my other jag today. Changing upper timing tensioners and all new plugs and coils. Whom ever designed this engine bay should be beaten. lol No consideration was given to repairs. One side done, one to go. May have caught a tensioner problem just in time.
The following 2 users liked this post by davidladewig:
Grant Francis (10-19-2016),
Warspite (10-20-2016)
37driver
10-07-2016 04:47 PM
Gerry755
08-31-2016 07:49 AM
Peter Jones
08-24-2016 08:12 PM
