2002 s type R brake rotors
Hi everyone
well my donor STR has been completely stripped out
Shell only now
Massive job
So have started stripping my crashed STR
engine and transmission out
But just found i have a cracked brake rotors
and the ones on donor car are different
Donor car rotors are sold
Yet the ones on mine are cross drilled and sloted
I have looked on sng Barratt site but can't find them
On the inside of rotors it says jaguar but I can't see a part number
Would anyone know where do you get them from
Shell only now
Massive job
Front or rear?
They come solid stock so the drilled and slotted ones are after market. Or are you saying the slotted and drilled ones are marked with Jaguar?
There were a few differences too?
Post the last 6 digits of your VIN for better identification. When I had my R I found there is an awful lot of wrong information in that many listings say R but they are the wrong size.
One last thing? That 2002 is a very early STR so I would not be surprised if it was different from the later ones. Measure the rotor diameter just to make sure what you have. As posted above Jaguar dropped Brembo and went back to the conventional floating caliper design with the ATE branded stuff.
Rock Auto does sell a Pagid brand 365mm diameter rotor for about $85 per side.
He gave me the number where I can get them done
DigitalDisaster
07-31-2017 11:34 PM
bklynchris
09-27-2011 05:41 AM
metalmarty
30
10-15-2010 07:52 PM
