2003 Jaguar S-Type, 4.2 L codes
Hey everyone, new to the site here. Looking for some info on some DIY repair for a few codes that are coming up on my Jag. It is a 2003 Jaguar S-Type, 4.2L, not supercharged. Trying to get it to pass emissions tests here in TN. It is currently throwing out:
P0105
P0405
From what I can tell it looks like maybe the MAP Sensor needs replaced. Is this pretty easy to fix? Any info would be greatly appreciated.
P0105
P0405
Tide311: I suggest you search this forum by the code #'s for more info on these subjects. Below are what the book says about these codes and possible fixes. FYI: There is supposedly a good Jag/import shop on 4th Ave South close to the old City Cemetary--where it's one way going south. There is another very good Jag shop across Murfreesboro Road from Vultee Church of Christ--but he doesn't work on modern electronics. Good luck!
P0405 V8 EMS
OBD II
EGR valve drive circuits low voltageOBD II
EGR valve power supply circuit open circuit
EGR valve to ECM drive circuit pair
(EGR valve pins 1/4, 6/3):
open circuit, high resistance
EGR valve failure (stepper motor open circuit)EGR valve to ECM drive circuit pair
P0105 EMS
OBD II
MAP Sensor circuit malfunctionOBD II
Intake manifold air leak (loose or missing
component)
MAP Sensor to ECM circuit(s) fault
MAP Sensor failure
Throttle adaption fault (check throttle position
voltage at Ignition ON)component)
MAP Sensor failure
stanjag
08-30-2015 10:35 AM
Terrance Williams
08-26-2015 11:50 AM
NinoGrimace
08-26-2015 05:15 AM
