2003 S Type 3.0 V6 Restricted Performance
#41
2006 SType 3.0 Restricted Performance
My 2006 S-Type 3.0, has started sputtering when idled. Sitting at a red light in drive, it acts like it's going to cut off. Then a Restricted Performance light came on. I took it home a parked it.
It has 56k miles on it, had a tuneup less than a year ago. Can't remember if the battery has ever been replaced
Help, As a female I don't want to get stranded or took by untrusty mechanics.
#42
#44
Maintenance, Repair, Jaguar, Rover, Mini, Ferrari, Exotics, Portland, Oregon
#46
Now that my fuel pump has been replaced car is running ok, keeps getting check fuel filler cap and eventually a check engine light. I've taken it back to my mechanic 3 times now. He rechecked for leaks done a smoke test. After about 20 miles or a couple Starts the error returns. Help frustrated!!!!!!
Last edited by farak26; 01-18-2016 at 08:40 PM. Reason: New problem Check fuel filler cap S-Type 2006 v3.0
#50
Is the fuel cap message new? Carefully inspect the sealing surface on the filler neck, where the fuel cap attaches. It could be dented from contact with the gas station fuel nozzle. The smoke tester might still be able to seal properly, but not your fuel cap.
If there are no dents, I'd gamble on a new fuel cap.
Also, next time you get the check engine light, report back with the actual 5 character code. (Should be P followed by four numbers) Many auto parts stores will read codes for free.
#53
#54
DFW
10-01-2015 08:22 PM
KarimPA
09-27-2015 09:46 AM
