2003 S Type 3.0L AC expansion valve location
Received 6,361 Likes
Welcome to the forum.
The answers here https://www.jaguarforums.com/forum/s...ocation-73184/ but you won't be able to open the attachments until you go through the new member process.
Jaguardave (07-17-2012)
I would press the issue of the necessity of changing out the expansion valve. Just my $0.02
as for the drier bag looking at the front of the car it will be on the left side have to drop the front plastic pan off under the bumper you will see an aluminum plug with a large hex-key hole in it, that is where the drier is located note that most places do not carry the thing got mine from here:
Jaguar S-Type A/C Accumulator/Drier | Part Number: 60-31024 | Discount AC Parts
boat load cheaper than Jaguar oem and works great, odd design though. hope this helps, as for the expansion valve it looked a *&^$% to change from the engine compartment on my 03 R model, had the whole dash and box out so just did it then. good luck! dont forget to flush out everything!
X_Type_South_Africa
12-09-2015 05:37 PM
stanjag
08-30-2015 10:35 AM
Terrance Williams
08-26-2015 11:50 AM
