2003 s type abs and dsc fault
coming home on turnpike drive over rumble strip at prescribed speed at the tool booth, abs and dsc lights immediateily came on and got abs fault and dsc not available in the dash display, cruise control was then disabled. after parking at home, and restarting, the dsc light went out but still have the abs fault. what can I do to clear it? havent tried it this morning yet, can I trust the
autozone or o'riley readers to celar it? or can they?
Could be a bad connection, whether battery or ABS, or a genuine ABS problem - which could be rust on the sensor rings, a loose ABS sensor - or even a failing wheel bearing.
Anyone with a jag-specific tool could read the codes in the ABS module if you want to know what it detected. Its light will self-clear above some lowish speed (10mph?) if all is now OK.
jgoode (08-05-2012)
+1 on JagV8's advice on getting the codes scanned. You will need a Jaguar specific code reader to get any abs/dsc related code(s) - A normal OBDII reader will not do the trick - good luck. When you get the code(s) research the forum - otherwise post them and we'll steer you in the right direction.
Hoping you never get the dreadded abs/dsc fault... just my $0.02
