2003 S-Type R Amplifier Compatibility Questions
I just bought a 2003 S-TYPE R Jaguar, the Cd, Radio, and Navigation all worked, except there was no sound, all the fuses were good and i removed the main amp (2R83-18C808-BA) in the trunk on top to the cd changer, and it looks like water got in it and need to replace it. My question is, can i use an alternative or does it have to be the same one? i did find one on the internet from an X-Type it looks exactly the same (4X43-18C808-AC), same plugs in the back, can i use this one, or any other suggestions? Let me know, thanx
I would guess that since the wiring looks the same, it was "probably" pinned the same in the plugs. Alot of auto companies, use certain items across models or years. I could see them doing this with an amp, but truthfully, I think the only way you would know if it works, is if you tried it. It will either work or it wont.
Might be safer to look for an S-type that has it for sale.
yeah my factory Jaguar Amp is def fried, i took it apart, it looks like the previous owners let water get in there, its burnt with green corrosion on the bottom of the motherboard, i'm gonna buy the Amp from the 2004 x-type and see if it works, both have premium sound and it looks identical, even the same plugs, cause them things are expensive from the dealer, they want $1000 for that Amp, thatz alot for an Amp!
neruda
10-18-2015 01:19 PM
al_roethlisberger
09-09-2015 09:14 PM
OkieTim
09-08-2015 04:48 PM
