2003 S Type R Brake Issue
I have an 03 STR with no brakes. I have swapped the ABS module and master cylinder out with no change. We have bled it on multiple occasions with no change. If you rapidly pump the pedal you can get a little bit of pressure but the pedal sinks to the floor. I have tried running a hose from the master cylinder bleeder into the reservoir and I get a little bit of air every time. No more air from the calipers or when I crack the lines on top of the ABS module. It seems odd to me that there is no difference between two sets of masters and abs modules. Any thoughts?
Thanks,
David
Thanks,
David
