2003 STR IAT2 sensor help
Been looking on the forums for a solution to my p0097 sensor 2 circuit low input issue along with P0443 purge valve
not sure if they could be a related problem or not since both of my banks are running lean at the moment.
p0174
P0171
positive feedback ONLY please.
p0174
P0171
That leaves a question - what are the LTFTs & STFTs?
For the smoke check, did the test include the duct immediately downstream of the air filter? This poor piece typically gets removed to connect the smoke machine, and thus overlooked as a possible source of the vacuum leak.
You may find this thread helpful:
https://www.jaguarforums.com/forum/s...solved-198690/
Not your exact model, but two forum members had the identical root cause while chasing similar codes and high LTFT values.
discuspro
04-24-2020 09:11 PM
HushmoSTR 2003jag
11-15-2014 01:37 AM
Petersonj1987
03-21-2014 03:26 PM
clubairth1
11-05-2011 07:08 AM
