2003n s type fuel pump
Old 12-04-2016, 10:13 AM
capthale's Avatar
Default 2003n s type fuel pump
I recently swapped fuel pump, all relays and fuses have been checked. now when I try and start car...nothing. I don't hear the fuel pump kick on to prime system. was told that the ecu needed to be reprogrammed to recognize new fuel pump. HELP!
Old 12-04-2016, 11:28 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
No reprogramming needed.
If it doesn't run at all you're looking at fuse, relay, wiring, connector, cut off, etc. Start with the circuit diagram & workshop manual if you want to DIY.
Old 12-04-2016, 03:54 PM
capthale's Avatar
Thanks, I checked all fuses. Now battery is extremely low. Ill charge it and try again. Will post results in the near future.
Old 12-04-2016, 05:00 PM
JagV8's Avatar
Forget doing any diagnosing with a less than great battery. Just asking for false problems all due to it.
Old 12-05-2016, 10:08 AM
Jumpin' Jag Flash's Avatar
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
+1
Battery must be fully charged when troubleshooting.
