2004 fuel pump
Has anyone ever replaced the factory pump with an aftermarket one?
I pulled the assembly out and applied 12 volts directly to the pump and it does not run.
I am not going to wait for 2 weeks while paying $350 plus shipping for a fuel pump to be delivered to Guam. There is a large JDM scene here so I am sure I can find a fuel pump of the appropriate size and fuel pressure flow to put into the stock assembly, however if someone else has done this already that would be great. I did a search and have not seen anything on this forum about it.
Just reaching out in hopes someone has done it so I can find out what pump was used....
Thanks. If I can't find anything by Monday, I will forge ahead and make it a DIY.
Crickets.... Damn.
Morning here in Guam, off to get the fuel pump.
I'll post the Napa part numbers and the photo's on the assembly once I get it all buttoned up.
I am pretty sure there are cheaper alternatives back in the states for this fuel pump but I have carquest and Napa. And neither one stocks a decent selection of parts.mthey order what they think they won't hold onto forever
Just be sure it's the right pump.
You do know that the S type has two fuel pumps and they have different functions? Also if you have an STR it has a completely unique fuel pump set up unlike any other S Type.
They are also PWM driven so I hope the Ford pickup one is too. It's not like the old days where you put 12V on it and go.
There is also a module the drives the pumps. Are you getting power to the old pump?
It fits and works just fine. I took pictures with my phone and tablet so once i get them in one place i will write up the DIY
Had some pm's asking about how it is working.
Starts right up,
However, I damaged the intake manifold gasket putting it back together.
So I just disassembled it again this afternoon, and dropped in a new victor reins set.
Cranked for about 8 seconds and fired up.
Now I get a p1000 and p1647
Time to replace that drivers side upstream O2 sensor!
Got a few things more important than uploading photos on my plate with work and moving back to the states in 6 weeks. I'll get the DIY done shortly
Starts right up,
Norri (11-17-2015)
XJLFTW
11-10-2015 12:41 PM
