2004 Jaguar S type CEL on
I took my 2004 Jaguar S type 3.0/6 cylinder (USA) to the mechanic because my check engine light came on as well "restricted" performance" notice came on my dashboard.
They ran a diagnostic check on the car and told me it was misfiring from the right side of the engine (passenger). Though they could not exactly find the reasons that are causing it. I rather just fix it myself to save money. I just want to know the problem. I read other owners have had this problem and sometimes can't find the problem after replacing so many parts.
Here are the results from the Diagnostic CHECK
P0 301
P0 303
P0 305
Thank you
P0 301
P0 303
P0 305
Thank you
The following 2 users liked this post by joycesjag:
Jumpin' Jag Flash (11-24-2015),
projectjag (11-18-2015)
If you intend to keep the car for a good length of time, consider getting your own code reader, preferably one specializing in Jaguars (there's a thread on this forum where there are many suggestions for make and model) as there are some codes that generic scanners cannot report on.
Most choices are $100 or less. Good investment.
Received 6,307 Likes
Welcome to the forum projectjag, I've deleted your other identical post.
Please post an intro in the new members section.
As previously suggested, I'd replace the IMT O-rings first. Get genuine OEM O-rings for this application, not aftermarket. They weren't expensive. Clear the code and see if it returns.
The next thing I'd look at is if oil has collected in the spark plug wells. The plugs share a common well, so a leaking valve cover gasket will short out all coils on that side.
Valve cover gaskets are not expensive. The only downside is access is very poor on the (US) passenger side due to the big swoopy intake plenum in the way. It's not real bad to remove, but a bit intimidating the first time.
If you do find oil there, don't despair. That's a fairly common thing and easy enough to fix with a new gasket set. There's a good chance, however, that those three coils have burned out if trying to fire with the tips submerged in oil. Normally I'd just say clean them off and try them, but it would really stink to have to pull off the plenum again. So I'd say just replace them for peace of mind. At the very least, swap the known good ones from the other bank, as those are super easy to access.
Also, I'd suggest a new set of spark plugs while you're in there. Cheap insurance.
While you have misfire on the mind, you can read my thoughts on the term from another thread when I was up on my MisfireSoapbox(tm)
https://www.jaguarforums.com/forum/s...firing-146818/
projectjag (11-21-2015)
Thank you for your input kr98664. It is very helpful and I'm going to give it a try. I just wanted to know when it comes to the spark plugs if by any chance do you know the original metal that is used for the S type? Iridium, Platinum, or Copper? Also do you think it matters if I use the original brand or not?
If you need better advice, perhaps somebody more knowledgeable can chime in.
