2004-S AC trouble
Guest
Posts: n/a
2004-S AC trouble
When I have the AC on, either in Auto or Manual mode, it blows extremely hot air or cold air changing back and forth between the two. The Jag service manager said it is probably the In Vehicle Sensor. The Jag parts man said they sell very few of these sensors, so I'm thinking that sensor is probably not the problem Please help if you can.
RE: 2004-S AC trouble
I just started having a similar problem with my STR. I was told that the Evap Temp Sensors are probably bad. These sensors are sometimes called Air Discharge Temp Senors. I purchased two of the sensors and will install them tomorrow. I will let you know if it solves my problem. The sensors were only around $22 each.
my car is in for the same problem it has some b code's i don't have them at this time's they ordered somesensors they put them in but still having some problems i talk to them like a hr. ago they are installing a new heater valve aslo and they are still working on it. i belive the install sun load sensors and temp sensors and blend door actuator motors.
Guest
Posts: n/a
Hey Buddy: Wondered if I could get a bit more detail on this issue. '03 S-Type V8 ACC problem arising. When temp on unit set below 75 degrees cold air blows all sides & rear vent. Heat only when above. When blower speed reduced to 1-bar & car in idle then heat is present but believe this is only from the engine! Are these sensors referred to as:
Air Discharge Temp Sensors or Evap Temp Sensors? And, what are the access points for replacement? The parts guy at my dealership doesn't seem to know what a Evap Temp Sensors is??????? Do you know the part number(s) & approximate cost per?
RSVP,
TerryJ
RSVP,
TerryJ
They are Air Discharge Temp Sensors or Evap Temp Sensors they are two different sensors. The Air Discharge temp sensors it not to bad to get to I did not see were under the dash but the tech removed it in like 2min's so it can’t be that hard. Here are some pics I would change out the Air Discharge Temp Sensors first then Evap Temp Sensors. If the air temp sensor dose not fix it, then chage out the Evap sensor. I had the same problem with my car. Cost $20 each there are two for the Air Discharge Temp Sensors $50 Evap Temp Sensors.
