2004 S Type battery drain please help.
Old 01-02-2014, 08:58 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
If the car has headlamp washers they're another nuisance beyond the rust.
Old 01-02-2014, 09:05 AM
JagV8's Avatar
That's probably it - diesel VIN started N14071 I believe.
Old 01-02-2014, 11:51 AM
leemancity's Avatar
Just a quick update I phoned a Jaguar specialist in Derby today and he was helpful so I taking the car up there on Monday or Tuesday so I will keep you guys updated i have fitted an isolator switch this evening so i can still use the car thanks once again for your help and advice so far
Old 01-12-2014, 06:01 PM
leemancity's Avatar
Hello chaps sorry for the delay I did take the car to a place in Derby called Elite Performance Jags.
They could not find a fault they stripped out the modules and tested them they were working so fitted them back in tested the drain again and it had gone only a 200 mil amp drain which I am told is normal for a S Type.
So it cost me £108 so I collected the car on thursday morning they had left it mon..tues..wed... night battery connected no drain.I drove back to birmingham on the thursday then Friday morning the car was dead again so they have it back at derby so i am back to square 1.
i will update you again soon hopefully with some good news.
Old 01-12-2014, 09:37 PM
gavin76's Avatar
hey lee i had a similar problem on a s type here and traced it back to the logic supply wire at the front electronic module, tell your technician to back out the wire at connector fh59-6 in the fem then re-run a drain test if all is ok i would just run another wire to that pin from fuse 20, this method worked for me you cant lose anything by trying let me know how it goes, look at the wiring diagram for your connector locations, fh59 is on page 28 of the diagram in one of the previous posts in this thread
Gavin
Old 01-13-2014, 01:18 AM
leemancity's Avatar
Thanks Gavin I will tell them and let you know how I get on hopefully it is a quick fix I hate having no car
Old 01-20-2014, 01:36 PM
leemancity's Avatar
Well its not good news they are convinced its the wiring loom as they have re checked everything else and cannot find a fault so it going to cost and its very frustrating
  #28
Old 01-25-2014, 01:35 AM
leemancity's Avatar
I have fitted an isolator switch as I said before so i can use the car but the problem is so i have been told the s type has 1 complete wiring loom so everything has to come out of the car i have also been told the dampness can cause it and there was water in the boot which i have removed and drilled 2 small holes for drainage.
do when or should i say if we get some warm weather i will recheck and see if i get a drain.
Old 01-25-2014, 02:01 AM
JagV8's Avatar
Don't believe all you're told.
ControlIssues
09-03-2015 07:38 PM
Thia
09-01-2015 10:36 AM
stanjag
08-30-2015 10:35 AM
EastFalk
08-29-2015 08:22 PM
Aegis21
08-27-2015 08:30 AM
Quick Reply: 2004 S Type battery drain please help.
