2004 S type oil leaking on/from oil filter?
My 04 Stype leaking oil on or from oil filter. I know TSB S30308 exists for earlier models leaking due oil filter loosening, but I can not unzip the file to read what the fix was. Can anyone tell me more about that or if that may be same problem plaguing me now? Is the car sensitive to filter brands? Currently have a Fram on, but same wet filter seen with Shell and motor raft filters used. Thanks.
TSB S30308 is for S-type MY 2000 for leaking oil filters - boils down to tightening the oil filter some more.
All is says is "
Action:
To eliminate the problem of oil filters becoming loose and leaking oil, a revised
tightening procedure has been produced and new special tool (oil filter wrench 303-752
supplied) introduced to tighten the oil filter to a specific torque of 18 Nm.
On a customer complaint basis only, follow the workshop procedure below.
All is says is "
Action:
Make sure the rubber sealing gasket from the previous oil filter did not stay attached to the metal oil filter base casing when your previous oil filter was removed and then your current oil filter was installed. A common error that happens every day and is guaranteed to cause oil leaks 100% of the time....
ellenm (03-25-2014)
