2004 S Type R coolant change
Hello
I have a 2004 S Type R that I am tryign to change the coolant on.The coolant is now 5 years old.Can someone tell me the procedure on changing it?I was going to change to Evans Waterless Propylene Glycol coolant.
I also wanted to change the Differential fluid and was going to use Royal Puple 75 W 140 synthetic gear oil.Will this work as the dealership does not recomend anything except jag gear oil.
Thanks Fitz
Thanks Fitz
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Your car uses Dex-cool. Much cheaper to just stay with the factory fill. I have changed the rear end fluid and it was black and nasty!! Please find the Jaguar spec. I have posted it on the forum before. I was able to match the Jaguar rear end lube spec at NAPA with a full synthetic fluid. I used a hand pump to suck the fluid out of the rear end so I did not have to remove the rear cover and change the gasket.
Here is my rear end fluid change post. Should answer all your questions.
http://tinyurl.com/242qfub
stanjag
08-30-2015 10:35 AM
