2004 str oem oxygen sensor
Pretty sure they're Denso. The jag part # likely is in that part PDF I've referred to numerous times. If you want Denso's #, maybe one of the forum sponsors will have it or try contacting Denso.
It's a linear aka wide-band aka AFR type. Not the same as the rear type or the type on the original S-Type. I wouldn't fit a near replacement, only the exact type. (It MAY be Denso part 234-9030 but I'd want some confirmation. From http://www.densoaftermarket.com/cata....php?part=o2sn)
You're unlucky if one's failed (they do, but not often). How many miles on the car?
Parts companies I've met do no or hardly any testing and do not know how to test most parts (other than "obviously broken" or "not obviously broken"). Nice (and surprising) to hear Napa are different.
I wouldn't fit a non-OE critical part such as an upstream O2 sensor unless 100% sure it was identical, but hey that's just me. The connector would not be a test for being suitable!
I've seen it first hand since I've been lucky to tour the facilities. We do real world testing on parts and compare white papers to ensure manafacture specs. are met.
Im running all 4 o2 bosch sensors from my local NAPA.
We are still in business because we make alternatives to OE parts, part of it is because we work with them to ensure quality, not a plug fits.. holes line up ok its the part solution.
NAPA does own a few Major part manafactures that work off car manafacture specifications to make parts, for after market.
Look us up and the history
See: http://www.densoaftermarket.com/cata....php?part=o2sn
Denso claims to be the OEM oxygen sensor mfgr for Jaguar
Front (air/fuel sensor) 234-9030
Rear (oxygen sensor) 234-4735
Amazon.com $87.62 each cheapest price I've found
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-03-2015 07:32 PM
