2005 3.0 Rear Tie Rod and Sway Bar Links Replacement W/Pics FAQ
Old 08-05-2016, 10:07 AM
neilr's Avatar
Sway bar links: If you are replacing, take a look at the Meyle ones. Top quality and the front ones are "heavy duty" so should also last longer.
Fronts: 2x Meyle 18-160600002/HD
Rear: 1x Meyle 18160600000
1x Meyle 18160600001
The following 2 users liked this post by neilr:
Jumpin' Jag Flash (09-23-2016), Panthro (10-01-2016)
  #42
Old 09-22-2016, 12:18 PM
cheers
  #43
Old 02-07-2017, 05:48 AM
solidaxel's Avatar
Originally Posted by Tijoe
I've been running my custom toe rods on my STR for a year and a half and last week I took a look at them to see how they are holding up. Other than a thin film of road dust, they still look brand new. (7000 miles)
On the other hand, I replaced the sway bar links at the same time with E-bay cheap Chinese links, and their boots are already split and half rotted away. They show show signs of rust on the welds. I suppose I need to find better quality rubber covers before the grease dries up.
Regarding your inner bushings on your tie rods, did you use rubber or Urethane, if so where did you find them?
the outer looks to be a heim in the pic.
Thanks for your help
  #44
Old 02-07-2017, 10:26 AM
Default of ebay
ordered off ebay cant tell you anymore tahn that , they are on
  #45
Old 02-07-2017, 04:53 PM
Tijoe's Avatar
My inner tie rod are standard 2002-2011 Corvette mated to a custom fabricated tie rod tubes. Outer are an off the shelf heim joint. Sub frame mount holes are drilled out slightly to fit the larger Corvette tie rod shaft.
solidaxel (02-08-2017)
  #46
Old 02-07-2017, 09:29 PM
davidladewig's Avatar
Originally Posted by joycesjag
Mannn you guys are killin' me. I can't win, almost every thread like this, I put an approximate time and I receive flak for not allowing for seized bolts either publicly or via PMs.
In this case the seized bolt/nut vehicles could become a PIA, unless of course you are lucky enough to own a set of torches.
stars and bars baby
I don't allow for any rusty stuff either. Why crush the dream of snow bound DIYer.
  #47
Old 02-08-2017, 07:45 AM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
neilr-can you tell us where you found that brand of sway bar link?
I have not heard of it here in the US?
  #48
Old 02-09-2017, 03:40 AM
neilr's Avatar
It is a fairly well known German component manufacturer and their quality seems a cut above the usual aftermarket stuff. They have an HD range of uprated components aimed at replacing those components that normally fail early, like S-Type front drop links
Online catalogue - MEYLE
Jumpin' Jag Flash (08-04-2017)
  #49
Old 02-09-2017, 07:12 AM
solidaxel's Avatar
Did you find them in the catalog?
  #50
Old 02-10-2017, 03:53 AM
neilr's Avatar
Fronts:
Rear:
These seem to be common across all S-Types
Panthro (02-13-2017)
  #51
Old 02-10-2017, 08:10 AM
solidaxel's Avatar
Originally Posted by neilr
Fronts:
Rear:
Thanks, I am looking for the Track rod or, tie rods, those look to be the end links for the sway bars
  #52
Old 07-30-2017, 01:37 PM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
Still a good write-up - thanks Rick.
Finally (*) had to do the other side (had to cut the rusted inner nut off, complete pain in the ....).
(*) car's 13 yrs old and 134K miles, so can't complain about OE quality.
joycesjag (08-17-2020)
  #53
Old 08-16-2020, 11:43 AM
Budgie's Avatar
Just about to replace mine and came across your post - Excellent - thank you - well explained and illustrated.
The following 2 users liked this post by Budgie:
joycesjag (08-17-2020), Sixx Dogg (08-22-2020)
  #54
Old 11-22-2020, 08:17 AM
graham-r's Avatar
This was a very useful thread - I have just had to replace the left tie bar on my car to get it through the MoT.
I thought I would add my tuppence worth, firstly the 7/8mm hex on the end of the anti-roll bar links (AKA sway bar for you USA types !) and tie bar respectively are way too small - they shear very easily on the anti-roll bar links, as I just found out. The latter will be attacked later with a nut cracker or grinder !
But to make it easier to fit the new tie bar I came up with a way of presetting the length before fitting it to the car - it was very high tech and was not cheap though.... (see the pics). it does assume that the original tie bar length was ok in the first place !
I know it is a really complex concept so if you have any questions........ :0)
Edit: I have bought some die nuts to chase the thread that is visible to try and clean up the rusty parts to make the nuts easier to get off - hopefully doing this will reduce the tendency for the nuts to tighten up to the point of having to back up to avoid it actually seizing completely. Hopefully this will make the remaining anti-roll bar links and RHS tie bar come off a lot more easily.
This view gives a better view of the general idea
kr98664 (11-22-2020)
mhamilton
11-08-2019 04:41 PM
TFG1067
07-05-2019 05:46 PM
sidescrollin
07-19-2016 04:16 PM
morrison
02-05-2012 06:58 AM
fabfive
02-25-2011 05:19 PM
Quick Reply: 2005 3.0 Rear Tie Rod and Sway Bar Links Replacement W/Pics FAQ
