2005 aluminum window trim removal w/pics FAQ
#61
#62
Well, there are two very thin strips of soft rubber on both sides of the channel (that is what the problem was, the edge of the rubber seals interfered and got in the way) that I guess you could call double sided automotive tape. I have used it before on other applications, and this is a little different, but it is still in good shape. It is soft, sticky, and pliable.
#63
Not sure if these clips will work but for 0.75 US cents worth a try.
Let you know how I go.
They look remarkably similar!
1968-70 AMC AMX / Javelin Door/Quarter Trim Molding Clip
#64
Tom on Dallas/Plano
05 S-type 3.0 93k
#65
They look similar but with the protruding piece on top- you will need to cut that off- or you will never get the side pieces to fit where they should. The side pieces do not look like they are as thin as the Jag version, but that could be the photo. I would suggest just trying to slip one on the trim piece and see what you have before putting them in the body of the car.
Tom on Dallas/Plano
05 S-type 3.0 93k
Tom on Dallas/Plano
05 S-type 3.0 93k
#67
Yes you are right about the locking pin. Must be getting older. It may still work if the footing is big enough. Just have to try and find out. You could also use a lite epoxy to help and also the epoxy tape that Rick (joycesjag) talks about.
Tom
clubairth1
29
05-10-2024 12:57 PM
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
