2005 cabin/pollen filter replacement w/pics FAQ
Difficulty level: novice
Tools needed: stubby (short) 8mm torx with 1/4" wrench or 1/4" swivel socket (pictured)
Time: less than 15 minutes (cold 1 break included)
Remove 4 push/pull pins, remove 2-torx screw cowl access covers (thumb nail) remove 2- T20 screws, gently lift cowl cover with left hand, push 2-thumb tabs lift filter cover (note 2 black arrows in photo), lift filter up and out.
Install, reverse procedure
per passport to service manual, this filter should be changed every 10,000 miles (16090 km to our metric friends)
The following 12 users liked this post by joycesjag:
danveenstra (09-02-2014),
Datsports (08-22-2015),
davidladewig (07-10-2019),
devo357 (03-06-2014),
Jumpin' Jag Flash (10-27-2013),
and 7 others liked this post.
Received 9,007 Likes
Rusty0XK8 (12-29-2012)
Adding to Rick's excellent write up:
There are two different cabin filters for the S-Type depending on VIN. I must have an earlier version than Rick's since I did not need any tools. I removed the 4 popup pins with my key and then removed the filter after popping the two filter covers. Somewhat to my surprise the old filter was a Ford Micron filter. Here are some part numbers:
FD02115 >PET PC<
2R83 180483 AD
Total time for mine was less than 5 minutes. No cold ones were consumed owing to the early hour on Sunday. I had to do it early since it has been over 100 degrees during the daytime.
FD02115 >PET PC<
2R83 180483 AD
Jumpin' Jag Flash (07-03-2016)
Interesting Mike, no torx screws? The original filter was stamped with a Jag number and my replacement is a Ford as I recall. I do not think ours was ever replaced simply due to the filthiness in it.
You forgot to mention the humidity factor as well, here it was been 100+ F and 97% humidity! I thinkng I might start off today with a cold 1.....or 18
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
You forgot to mention the humidity factor as well, here it was been 100+ F and 97% humidity! I thinkng I might start off today with a cold 1.....or 18![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
gcgjohnson (12-02-2012)
I noticed the same thing. I had to adjust my temperature setting up by 2 degrees because I was starting to get cold. Ravages of old age I suppose as well.
Just pulled mine out, I had to pull the push/pull pins and all of the torx screws to get at mine. I had no idea what I was doing so it took about 20 minutes before I got the hang of it. My filter was a Mahle LAK250, and it doesn't look that bad. Since I went through the efforts of pulling it out I will replace it. I hope NAPA has one in stock!
