2005 fuel sender locking ring removal question
Welp, finally broke down and ordered locking ring and the oring for sender unit from SNG Barrett this morning. About a week until delivery, $25.00 for plastic locking ring and I can't recall oring price.
Joyce is tired of guessing how much gas is in tank. Fill tank up fuel needle goes to full tank upon nearing empty tank, needle drops just below the 3/4 rank mark. The digital distance in dash basically acts same way.
Of course I will be the guinea pig again. I will finally figure out how to remove the facelift locking rings!
aholbro1 (05-10-2019)
I was under the impression that the S-type had two sending units, one which covered a full tank down to 1/2 and one from roughly1/2 to empty, with the car's internal circuitry determining which sender's signal was reflected on the gauge. Is the STR somehow different than the lesser S-types?
Received 6,337 Likes
#28
#30
wonderful jag engineering!! the screw clamp has a breakoff bolt head! It shears at the correct tightness! I guess the mechanics are too stupid to torque them (4nM). However, I cut a slot in the broken portion so I could get a screwdriver bit on it - then the remainder of the tin (it was fairly soft) broke off of what was a normal hose clamp hex screw! That allowed me to use a 1/4 drive ratchet, laborious as could only get a couple of clicks at a tiem, but it came off finally. Hope this info helps someone. The plastic cap was split. The cap is outrageous at $130 to $180.
roger.neill
02-26-2024 07:09 AM
nse1355
26
03-17-2022 12:44 PM
hollywooddippa
02-02-2017 12:28 PM
