2005 jaguar s-type 3.0 wont start
I have a 2005great jaguar s-type 3.0
Ok well i drive it around town it ran pretty fine to me no problems nothing at all i went to the store got out and locked it like normal i came out of the store unlocked it and went to start it and no sound at all it didnt even start everything worked lights navi radio windows all nine yards worked but would not start period it didnt even make sound when you tried to start it not even a click had to get it towed home could anyone help me please
That said, adding another battery can be achieved with jumper cables and see if it starts. I wouldn't jump right away with replacing the battery. But, if using a second battery fixes it, then replacing the battery would be my next move. Knowing full well that it may or may not fix the issue.
After that it becomes a systematic check of all the circuits that are tied to ignition. That is where diligent testing comes in. Ignition circuits, fuel circuits, etc.
To answer your second question... the "everything still works fine" is really just the accessories. Obviously, since it won't start, everything is not fine. Yes, even when the current is too low to start the car, accessories will still work.
Ok i tried letting the batery charge still no start i tried jumping it cause dealer said to still no start i guy on my street had a batery tester and he tested it and it had a 12.11 v when the batery says its a 12vv6 so i say its very good still? And how do i check the ignition fuses? And all that good stuff i mean pep boys is the only auto store that puts cars on those things to see codes would it thro a code? Honestly i dont know were anything is on this car my uncle said fuel reset button? Does it have one? Where? Would it cause this? I mean the car drove very good 5still mins before all this
It should be 12.6 or so.
If it might be security Search and read on PATS
Chances are it's the battery and you could spend forever testing everything else (or at least do a proper test with a hydrometer).
Till then spend TIME and EFFORT on here reading all the threads about cars that won't start and what people had to do.
Knowing the S-Type as I do, I also consider it rather likely that the OE battery needs replacing after eight years.
The OEM battery in my 05 was white.... sounds like you have a very old original battery.
So I had the battery tested came back good 97% but could it be the fuel pump ? Or wouldn't it still try to start ? But when I try the red light on the dash flashes fast so is it the security system ? I don't have the remote to it so ? What should I do can pep boys put it on the code scanner would it through a code?
My gut is telling me it is an issue with the security system. You still haven't answered if it is an OEM system or aftermarket. Please take some time to read up on some of the related threads. Again, all this is speculation. Kind of like doing surgery remotely.
1964Daimler
09-02-2015 11:41 PM
stanjag
08-30-2015 10:35 AM
NinoGrimace
08-26-2015 05:15 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
