2005 s type 4.2 v8
Old 08-29-2016, 07:03 PM
spots123's Avatar
Default 2005 s type 4.2 v8
I am getting a rapid beep sound when I open the door. Stops in about 5 seconds. Reoccurs when the engine shut off and again stops in 5 seconds.
Second problem the button on the dash will not open the trunk, the key for opens the trunk and the manual open also works.
Any help for me would be appreciated.
Jerry Spots 123
Old 08-30-2016, 01:52 AM
JagV8's Avatar
Received 4,528 Likes on 3,938 Posts
What does it do in each of these when you open the door:
1. with engine on
2. engine off but ignition II
3. engine off, ignition I
4. engine off, key in, ignition off
Old 08-30-2016, 09:32 AM
Kewpie's Avatar
Check to see if the valet button in the glove box is pressed. If so, button on dash won't work.
Old 08-30-2016, 11:36 AM
spots123's Avatar
in all cases no beeping sound when you open door.
1. with engine on
Jerry
Old 08-30-2016, 11:40 AM
spots123's Avatar
what an idiot I am. Your reply solved the problem.
Thanks, Jerry
NCJagman
02-06-2020 03:17 PM
Chad
09-12-2016 10:19 PM
lancervi50
08-30-2016 02:04 PM
Uncle Fishbits
08-16-2016 10:39 AM
capt
07-12-2016 05:58 PM
Quick Reply: 2005 s type 4.2 v8
