2005 S-Type 4.2: Water Pump needs replacing, what else should I get done
Hey Folks,
Still loving the S-Type 18 months after purchase, but now I have a water pump leak. Along with ordering a new pump, I got a new lower radiator hose and thermostat...just figuring that I might as well get them all done while the water pump is being replaced.
Question is, is there anything else I should go ahead and get done at the same time, to save future trips to the shop? (Note, the car now has 115k on it, I can't figure out how to change the Sig...) I was thinking that maybe I should get all the belts and tensioners changed as well, but I honestly don't know if it's worth the additional cost. Any advice would be appreciated, as always!
I think if you have the NA 4.2L you can get an Aluminum thermostat housing to replace the crappy factory plastic. Not many water pumps reported leaking but a lot from the plastic cooling parts in that area. So be prepared for something to break when you take it apart.
Your top tank or degas bottle is usually replaced before 100K miles? Is yours still original? It's on top so you can change it anytime really.
Yes change the serpentine belts. You have the latest and best timing tensioner set up. No need to worry.
The main thing is have the plugs and possibly the coils and cam cover gasket been changed? Only the plugs are called for but the others should be considered wear items too.
Of course the famous DCCV should also have been replaced by this time and possibly the AUX coolant pump along with the attaching hoses.
You did not ask but have you serviced the transmission?
jmcGoBlue (09-15-2012)
Regarding the serpentine belts, are you saying that I should just leave the current tensioners in place and only change the belts?
Yes. Forget the tensioners for the timing chains. It's no longer a problem for your year car.
Have you flushed the brake fluid and changed the coolant? Don't forget the cabin filter and gas filter both are hidden and out of sight.
Glad to hear the DCCV has been changed as if left bad it can take out the climate control unit. We do have a repair for that but avoiding it is the best.
stanjag
08-30-2015 10:35 AM
