2005 S type Battery keeps draining
I recently replaced the battery on my 2005 S Type, after it wouldn't start. I put in a new a battery and it worked great for a good 2 weeks, and now the Battery is dead again. I suspect it's draining from somewhere but don't know where to start to looking. I checked the alternator and it's charging just fine. Has anyone had any similar issues?
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
I'd recommend you thoroughly search the S-Type forum for battery drain issues. Seems they are all related to a short / pinched wire somewhere, or aftermarket alternator that seems compatible but isn't.
I think TBird, JagV8 and Mikey are all knowledgeable about battery drain issues, but do search the forum first. There is at least one other thread running concurrently with same issue as yours. Search is your best friend on the Jag Forums.
It's a shame that Jaguar didn't provide the Climate control Module with basic protections for all ports related to operating modules at the vehicle.
Most of the electrical problems start in this module
The way to deal with the problem of electricity leakage:
Disconnect the + voltage from the battery
Connect an ammeter between the battery and the + connector
It is important to close doors and take out the key, that the trunk is open, there is a lamp that will add electricity flow.
Start disconnecting relays in the trunk and engine.
See which relay reduces current consumption up to 300 milliamps
If you did not find the connection between the relays and the power consumption, go to disconnect modules:
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
REAR ELECTRONIC MODULE
TRAILER TOWING MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
FRONT ELECTRONIC MODULE
Successfully ....
I added a 100A relay with a remote on the top of the battery,
You can order Aliexpress >> Battery Relay Switch 12V Remote Control Battery Disconnect Cut Off Switch Anti-Theft Battery Isolator for Car Camping Trailer
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
Successfully ....
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
Successfully ....
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
Successfully ....
Received 1,442 Likes
Suggest you go to the Stickies at top of this forum . . . .S-Type 'HOW TO' Guides > Miscellaneous > Quiescent Current Drain
https://www.jaguarforums.com/forum/s...-drain-123535/
Read the PDF attached to Post #1, then read posts 3 and 4. This Sticky may be a decade old, but the S-Types, this issue, and the solutions are still valid and worth repeating.
Best wishes,
Best wishes,
A simple visual check to for a known common problem is make sure that dust cover is going back across the ingnition barrel hole when the key is taken out.
If this tiny cover over the hole is stuck in the open position the car will not fully shut down after 40 mins.
This will drain the battery.
It may not be that, but is a simple one to check.
Mellow
Mellow
I think it’s possible. These relays are pretty cool imo and really cheap.
stanjag
08-30-2015 10:35 AM
DeaconHull
08-28-2015 05:26 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
