2005 S-type (Park brake fault,Gearbox fault, restricted performance)
Hi All
Could someone point me to the thread that deals with the issues in the subject line?
Long story, short. On my way home received the following messages in this order:
I also replaced the Emergency Park brake switch.
I am heading to the dealer but would like to be able to have an understanding before I go.
Any help here would be greatly appreciated.
- Park brake fault
- Gear box fault
- Restricted Performance
- Cruise not available
Elle924 (05-15-2013)
I love my Jag. Would Like to Keep It but.....
I took my Jag to the dealer due to the issues I am having "park brake fault, gear box fault, restricted performance, cruise control not available". Anyway the dealer wasn't able to tell me the source of the problems. It's not the battery (battery is new).
I am attaching the DTC codes that were pulled at dealer. Could it be that the ECM is going bad?
Thanks in advance for your continued support.
Don't worry about the ECM. Very rare to go out.
I am worried that your readout has a low battery entry. Your battery may be new but it's not performing up to snuff. At least when your dealer ran his tests.
This was a Jaguar dealer and they can't fix the problem? If that's true we will have little luck guessing from a distance on an internet forum??
How much did you pay for this advice? I think I would press the dealer a bit more. Seems like he just left you hanging?
Received 2,266 Likes
Here's what's in the attachment. The bolding is mine. The dealer can't figure it out? Sounds like they are as incompetent as the one I used to deal with.
DTC
Description
Relevance
U2522
CAN message timeout from the transmission control module 33%
B1242
Recirculating air flow door actuator – circuit failure
B1262
Defrost servo motor – circuit failure
B1265
Cool air servo motor circuit failure
B1676
Battery voltage out of range
P1000
System check not completed since last memory clear
P1643
CAN link engine control module/transmission module circuit/network malfunction 33%
B1503
Lamp turn signal right – circuit failure
B1676
B2888
Audio system media fault
U2522
U1900
CAN communications bus fault
U2526
Data missing for air suspension
C1094-00
Parking Brake apply switch – circuit failure
100%
C1782-00
Parking Brake release switch – circuit failure
100%
C1D00-64
66%
C1D07-15
Secondary parking brake apply circuit
100%
C1D08-15
Secondary parking brake release switch circuit
100%
C1D11-64
Parking brake release switch
100%
U0001-00
High speed CAN communication bus
33%
U0101-00
Lost communication with transmission control module
B1676
66%
DTC
Description
Relevance
U2522
B1242
B1262
B1265
B1676
P1000
P1643
B1503
B1676
B2888
U2522
U1900
U2526
C1094-00
100%
C1782-00
100%
C1D00-64
66%
C1D07-15
100%
C1D08-15
100%
C1D11-64
100%
U0001-00
33%
U0101-00
B1676
66%
Before spending any money I would put the battery on charge, for overnight at a minimum, 24hrs would be best. Then see if problems remain.
Dave
I love my Jag. Would Like to Keep It but.....may just keep
Yeah, it was Hennessy Jaguar in Atlanta. I felt the same way, it is their car and they can't tell me what the problem is.
I wasn't charged because last month they replaced my Emergency Park brake switch and at that time I was getting the "park brake default" message and a loud buzzing sound. So due to having the same issue and then some I wasn't charged a fee.
Thanks everyone. I like my car but it was disheartening news to hear from the dealership that they couldn't pin point the problem unless they start breaking down the car.
I will look into replacing the battery.
Elle924
Some quick info on s-types...
First things first...I'm in Atlanta also, in the Decatur area and I drive the same year model (2005) that you have except I've got the 4.2L version.
Please invest in a code reader so you can do your own code inspections. This way you can save money and stay on top off mantinence issues that pop up out the blue...check your codes at least 2 times a month. Your jaguar is packed with a lot of sensors and other electronic switches an as it get more miles on it they will start to show wear, so if you don't want to go broke then please keep a check on things.
Remember...Dealers make about 35% to 40% of revenue from the service dept.
My experience with Hennessey and other jaguar dealers is that if you don't know what's really going on with your car then they will milk you of a lot of cash that could be kept...Jag is all about profit and they don't really care whether your car runs good or not!
Find you a good independent mechanic that you can trust to work on your car.
I have and from time to time experience the same symptoms as your car. Like the professionals on here mention, go ahead an get you another fresh battery to start. Then you want to give your throttle body and all of the electric connectors a good cleaning. You may look up my profile name SUMRFUN, as I have comments made on the procedure for this cleaning. Everything your experiencing I have been through. I found answers on this forum and saved probably about $3000 in labor cost so far by doing stuff on my own...don't forget to look up my threads. Have a good day.
Park brake + Restricted Performance = New Battery
I am not sure if H.Jaguar cleared the codes. Just came back from the independent Jaguar mechanic who I purchased the battery from back in February 2013 and he said that he cleared the codes. He also stated that the battery is good. Weird thing was though he threw out that it could be the TCM but that he couldn't be "sure". Oh and that it would cost a little over $2K to replace it.
Thanks all, I will purchase a new battery today. I read on some of the posts here that Pep Boy's Bosch batteries are pretty good.
I will also pick up a codes reader.
Thanks again and have a blessed day.
What sort of diagnosis is that???? "You might have cancer and you might die, but I can't be sure" Find another doctor/car mechanic.
Re battery, I can strongly recommend Varta Silver batteries if you can source them in your area or by the 'net. They were OE when the cars were first built.
I've just ordered an H3 100a/hr 830cca unit and eagerly awaiting delivery.
VARTA SILVER dynamique H3 CHRYSLER 100Ah batterie voiture code 600 402 08 | eBay
Dave
I've got an Innovia 3130 code reader...about $175 at pep boys
2005 SType w108KMiles - Problems Persists
Well, I actually bought my battery from Jaguar, yesterday and had it installed. My heart sank this morning when the same messages popped up in the Message center.
I will clean the throttle body. I changed the air filter and cleaned the MAS.
If it turns out the transmission Control Module needs replacement I may have to say farewell to my Jag. It has been a great, great car. It still looks good to be a 2005 and even in it's disabled state it drives better than any of the cars on the road that are fully functioning. I have never had any issues with it since purchasing it in 2008.
I am little frustrated right now.
- Gearbox ( goes away if I keep driving)
- Cruise Not available ( goes away if I keep driving)
- If I turn the car off when both of these messages are active it will not start.
- Park brake Fault (this one is constant but goes away if I turn off car)
- Restricted Performance(this one is constant and for the most part does not affect drivability)
- If only these two messages are visible in the message center and I turn the car off and restart the car it will restart immediately
After clearing the codes, I'd be curious to see which one(s) come back. If there's a repeat of Battery voltage out of range or similar, it's time to start looking at wiring or charging issues. All the other issues are common to low system voltage condition rather than an actual fault within the components.
Question: do you ever get water collecting in the trunk/boot ?
No water but maybe battery acid leak
No, no water in the trunk. But you may have solved the mystery. I did notice battery acid in the trunk after the new battery that I purchased on Tuesday was installed. I kept the battery that I bought in February and that one was leaking. I am not sure if the tech who installed the battery on Tuesday damaged the "old" battery or if it had been leaking for the past 5 months. I called the shop and didn't really get an answer so I will have the Jag battery removed by my "shade tree" mechanic. Maybe the acid ate through something. I don't know.
See attached: I took a picture of the battery that I purchased in February before it's removal and it does kind of look as if something wet had been pooling from it.
If that turns out to be the issue, you are the man, Mikey!!
Take a look and let me know what you see.
