2005 S Type wont shift into gear
Guest
Posts: n/a
On the later S types, the two 8mm headed bolts that hold the trans cable to the side of the transmission work loose and at times completely fall out. Give those bolts a look before replacing anything. The later S types also had a different shifter than the earlier S, and are much more robust.
