2005 STR P0308 Cylinder 8 Misfire
Is there a common cause for code P0308? I’ve searched and found mostly issues with V6 and non supercharged S-Types.
I replaced the coils and plugs a couple months ago. The only other recent change is a Banshee Screamer intake. I can’t imagine the intake is the cause. Maybe I damaged a vacuum line in the process of installing it? I’m going to swap coils with another cylinder to start.
Is there something super common that I should look towards first?
What brand coil did you install? Some no-name specials and discount chain house brands have been known to cause trouble right out of the box.
S-Type Owner (05-23-2022)
I've been planning on rebuilding the supercharger and putting a 6% pulley on it, so I guess I'll replace all the vacuum lines and having the injectors reconditioned while the blower is out.
Could be an injector, but inlet manifold gasket leak is possible too. Try to see if there are any vacuum pipes coming from that branch of the manifold. If there are any, check them for leaks but also check their destination. Example: on some cars the vacuum pipe for the brake servo comes from one end of the manifold. If the brake servo leaks it induces a lean mixture on one cylinder (this is only general advice. I don't know if the V8 has this or not).
kr98664 (05-31-2022)
slmskrs
10-27-2015 11:47 PM
carlorner
07-06-2011 05:31 PM
