2005 STR SC with 130000
finally after several days of delay was able to get my 05 running. Required new battery. Bad water leak from front its too cold to start disassembling more of a spring job. I have a odb2 which gave me two codes PO 456 and PO 1643. it has a bad gas cap so that should take care of the 456. Please any information on the 1643 would be helpful at least for the research end.
As far as the leak with the volume its probably a bad hose,thermostat or water pump. started to push it out with higher RPMs.
thanks in advance.
thanks in advance.
hawaiianjag
12-20-2020 05:01 PM
