2006 s type stuck in Park (Fixed)
Hello, My 2006 s type is stuck in Park but the indicator light is on for Reverse. The car is in reverse because I cannot start it and the backup indicator bell rings when i walk behind the car. I took the j gate apart and didnt see any broken parts, no burnt computer board, etc. I hoookd up a volt meter and put 12v to the solenoid and it activated. Any suggestions what it might be?
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Hello, My 2006 s type is stuck in Park but the indicator light is on for Reverse. The car is in reverse because I cannot start it and the backup indicator bell rings when i walk behind the car. I took the j gate apart and didnt see any broken parts, no burnt computer board, etc. I hoookd up a volt meter and put 12v to the solenoid and it activated. Any suggestions what it might be? ![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
Cincy - you sound to have the 1999-2002 car, which is known for that problem. (See threads on here, if you want to know more.)
It does NOT apply to the newer models (2003+).
chadw - the other thing to check is the 2 bolts on the side of the trans where the shifter cable enters. Fairly often these work loose and can even drop out![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
(This problem does NOT appear to affect the early cars. Win some, lose some!)
chadw (01-17-2012)
I went underneath my car and followed the shifter cable to where the two bolts are. One fell off in my hand (thankfully) and the other was loose. I tightened them both, reassembled the j gate and voila! Saved me a trip to the shop! THANK YOU!!!
Great Forum...someone actually knows what they are talking about!
My 2006 s type jaguar periodically gets stuck in park! 4 service stations and even the jag dealership could not figure it out. It's always happened on flat level ground. I can let it sit a day, then it's fine again! Afraid to even drive it, because I never know where I'm going to have to tow it home from! PLEASE HELP ME! Thanks!
stanjag
08-30-2015 10:35 AM
