2006 S-Type V8 AC compressor replacement
Hi, Its time to replace my 4.2L V8 AC compressor. Has anyone done this job and would be able to share the best way to get the compressor out. It looks like the motor needs to be lifted and the steering rack moved, although it also looks like it may come out if I remove the air cleaner box and lots of other stuff in the way,
Its not producing any cold air and I have high pressure bleed through to the low pressure side. The compressor does run, but only for short periods and the low side is always high.
I can get an OEM compressor from Parts Geek for around $420 or a kit off EBay including a condenser for $235. I'm not sure about the cheap compressors, I don't want to do this twice. Any one have experience with the cheap compressors.
Thanks for the help
Thanks for the help
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
There are several discussions on this forum about compressor/dryer replacement, so I would encourage you to read as many of those threads as possible. One highly regarded forum member recommended AC Compressor, Condenser, Evaporator and More A/C Parts at Wholesale Prices - Discount AC Parts for reasonably priced replacement kits. I bought one from them and it's working out great on my '03 S-Type. I'm sure there are also forum sponsors selling A/C parts as well.
The following 2 users liked this post by Gerry755:
abonano (07-21-2016),
Jumpin' Jag Flash (07-31-2016)
parnelli
37
01-05-2021 08:44 PM
