2006 S-Type wheels
I’m looking for 2 wheels for my 2006 S type Jaguar. Searching ebay I see there is adifference between the 2004, 2005, 2006 and the
JAGUAR STYPE 2000,2001,2002,2003 & 2008 OEM ALLOY WHEEL 17 X 7 1/2, 10 Spokes.
Comments please on what the difference is and why they are not compatible.
Welcome to the forum Keith12,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
There have been many diameters and styles of wheels for S-Types, but they should all be compatible.
At the bottom of this message is a Jaguar wheel-fitting chart I've used.
The only problem I'm aware of with S-Type wheels is the various diameters and fitting over the large brakes of the STRs.
I replaced my original wheels with 18" XF wheels with not problems.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current Hers: '13 Lexus ES350
Current Mine: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past Ours: '05 X-Type 3.0/auto Jaguar Racing Green
Jaguar - Vehicle Bolt Pattern Reference
(Jaguar _ Vehicle Bolt Pattern Reference)
On these pages you can find Jaguar vehicles Bolt Pattern and Offset. This will help you in determining High or Low offset and bolt patterns of your vehicle.
Discounted Wheel Warehouse has provided this information for its customers to provide the very best service to our customers. We offer a large selection of Jaguar Wheels and Jaguar Rims also Custom wheels, Car Rims, and Truck Rims so please enjoy the web site and choose your next set of Custom Wheels from Discounted Wheel Warehouse!
YEAR MAKE MODEL COMMENTS
2000 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2001 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2011 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2013 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2014 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2006 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2007 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2008 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2009 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
The following 6 users liked this post by pab:
ElJaguar (08-02-2016),
JMC1 (11-07-2022),
joycesjag (03-11-2016),
Jumpin' Jag Flash (03-12-2016),
Keith12 (03-12-2016),
and 1 others liked this post.
Received 6,307 Likes
Ya, but he's look'n for 17" wheels so I don't think he has an STR or will run into large wheel issues.
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
If your car is a 2004 and up,(VIN --M45255 and up), there were 5 different styles of 7.5x17in wheels used. All or any can be used. In my view you car will look better if all 4 wheels are the same style!!!
You can see drawings of the different style of wheel in the Jaguar EPC(electronic parts catalogue) which you can download from this forum.
The EPC does not show any 17 inch wheels for cars earlier than M45255.
Na, olde school ways: if the wheels are all the same size, and you have two different styles, pair them on each side.
Jaguar - it's not an automobile, it's a Motorcar
Current Mine: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Jaguar S-Type - Specs of wheel sizes, tires, PCD, Offset and Rims - Wheel-Size.com
Here you go. These folks sell wheels for your car.
Busa (08-01-2016)
So, digging into wheels once again, offset is fairly crucial for loads on hub/wheel bearings. I think the specs on an X-type, eve though on the above list seems similar, would be greater on the front/AWD X than on our S. As Zappa sang, I may totally wrong, but FWD offsets are fairly flat faced to fit the CV joints.
Anyone have an incisive take on S wheel inter-changeability?
Distilling down the above chart, it seems like and S,F and 2010-2015 XJ fit; any 04-14 XJ&XJ-R; '12-14 XK&XK-R&R-S; and also, incredibly, X-types...
>X-Type wheels are liable to be too weak.
Never heard that before... I'm quite sure that Jaguar factory wheels are Jaguar factory wheels, they just differ in size and style. You can use practically any factory wheel the same or larger than what came on your car, but watch for clearance if you go too big. What you can't really do is go down in size (i.e., diameter) since the brake rotors, etc., may have increased so the wheels won't fit.
I replaced my factory 18s with factory 18s from an XF.
2015 JCNA National Slalom Champion Class M
Current: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
X-Type is a much lighter car with far lower HP and weaker brakes so all the stresses on its wheels are far less. The wheels are designed with the actual max stresses in mind so are substantially weaker.
You can second-guess Jaguar engineers if you know a lot but otherwise are liable to make errors.
JagV8 is right. Every wheel has a design load rating. Depending on the weight of the car and the speed it can achieve it will need wheels certified for a particular car. The Germans do this properly and when you go to buy an aftermarket wheel, you have to make sure it is certified for your car.
Obviously, car designers do this too but they just don't give you any information about it. Smaller, less powerful cars will need, or even desire, lighter wheels to maximize performance and minimize consumption. These may not be strong enough for a faster and heavier car. Therefore, using a wheel designed for a smaller car may not be a sound move.
Then just search for a set of Jaguar wheels for either your car or a larger one. That is, don't use X-Type wheels, but XF wheels work fine (I should know, they're what I'm using on my car).
You should be safely able to use the same diameter wheels from S-Type, XF, or XJ.
>XF is just a modified S-Type...
Tis true, but I think they started putting much bigger wheels on them. Early on the offered the 18" but by 2012 or so I think they'd all gone up to 19s and maybe 20s were offered as options or were stock on the Rs...
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
