2006 STR wheel sizes
Frankola (11-12-2019)
With optional factory 19" rims, the '35' and '30' profile refers to the tyres sidewall height as a percentage of the tyres width.
The front tyres are narrower than the rears, therefore to achieve the same overall rolling diameter as the '30(%)' rear tyre profile the '35(%)' front tyre profile is required .
For example, the standard S-TYPE R tyre sizes are 245/40/18 on the front, 275/35/18 on the rear.
Hope this helps, my explanation is probably not the best !
I think the 'Barcelona' 19" wheels were standard fit on the last 2006 S-type R's? Or at the least many of them had them fitted from new.
As far as I know the tyre size from the factory are as follows:
Front: 245/35 -19 (On 8" wide rims.)
Rear: 275/30 -19 (On 9.5" wide rims.)
It should be noted that the 'Barcelona' 19" wheels were also available as an option on the rest of the S-type range, but unlike the 'R' the rim sizes were the same 8" on the front and back.
The 19" front tyres and wheels are only 2mm smaller in total outside diameter to the 18" ones.
The 19" rear tyres and wheels are exactly the same outside diameter as the 18" ones.
Simon.h
12-11-2015 11:10 AM
jagatlast
22
10-09-2010 12:02 PM
