2006 StypeR
the codes (P0171 P0174) are telling you the engine is running lean on both banks . and the codes p0420 & p0430 are telling you that the previous two codes are causing imminent damage to your cat converters .
you need to stop driving the car !
its doing damage .
you need to find the reason for this lean condition . wether its an air/vacuum leak or pore fuel supply/pressure .
with the STR the most common air leak is the push connector on the intake elbow for the brake booster vacuum line .
its doing damage .
