2007 brake pad replacement
Received 2,263 Likes
If similar to 2003 M/Y, there's no Allen head bolts that need removing to change pads, just a pair of six point 11 or maybe 12mm bolts that attach the caliper to the anchor bracket.
The only fiddly bit on the rear brakes is releasing the EPB , then screwing the piston back into the caliper. Have a look through the archives, the brakes have been covered many many times. Also- please stop by the new members section to post an intro.
Simple job in the end
You need:
a 9mm Allen socket of Allen Key
there are two plastic covers on the rear of the caliper
the allen bolts are beneath.
the R logo on the face of the calipers is actually a retaining spring clip, remove this with a screwdriver or suitable lever between
the clip and caliper directly under the R itself.(take care it will fly off if not restrained)
then remove the two 9mm bolts, the caliper then separates and the old pads can be removed.
On assembly I replaced the bolts loosely then fitted the clip.finally tightened the bolts and pressed the brake pedal to re-seat the pads.
took less then 40mins to do the Fronts.
You need:
I completed all four rotors and disc and had to open the fronts back for the springs, which didn't come with my ceramic pads and vented cross-drilled rotors. In less than 10 mins you can remove the tire, use a ratcheting 12mm wrench to remove only the top caliper bolt and swing the caliper down. then both pads simply slide up. The parts kit can be found locally
by asking for a
2000 Lincoln LS brake disc hardware kit by Duralast part #H5942
at Autozone
Duralast/Brake Disc Hardware Kit - Front (H5942) | AutoZone.com
It is the same I installed it.
by asking for a
at Autozone
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
