2007 S-Type audio lost
While driving, all of a sudden, no sound. In pulled over, shut down the car, then restarted. Still no sound. There is no sound in the radio, nav and the phone system has stooped working.
I checked the fuses I thought could be the issue, all were good. Just some quick background to when the sound quit. I had just got off a highway and stopped at the stop sign. As I turned left, all sound ceased. I am not sure if that info would help in narrowing down my issue.
Thanks to all in advance who may be able to help.
klitfin (06-21-2018)
This happens to me almost every time at a stop light with the pole mounted lasers. It even turns the clicking sound of my blinker off. Luckily it only lasts until the light changes. You may need to hook into a scanner to read the audio module. When I did with my solus pro it had set a couple codes but not hard codes. Sounds like you may have the same issue but with a hard fault code that may require a radio reset requiing your factory radio code that came with car
MikeofBonsall
10-30-2016 06:04 PM
