2007 S-Type - Secondary Air Injection Monitor
I have a 2007 S-Type in the shop that originally had a P0414 for the Air injection switching solenoid. We replaced the solenoid and cleared the codes. Then road tested to satisfy the monitors. We completed all the monitors with the exception of the Secondary Air Injection Monitor. The car has been through many start up cycles, and I am very surprised that this monitor has not completed. One week later, I have coupled up my handheld scanner to see that the Air Injection Monitor still hasn't been completed!
Does anyone have any insight on what it takes to satisfy this monitor? I can't find a published drive cycle for the Sec air injection. Is there a PID that can be monitored to confirm the running of the test? The Autologic tool wont retrieve the Mode $06 Test ID#71 that is associated with this monitor. Any suggestions?
My P0414 is x350 4.2 NA SAJWA71BX6SH07592 . I found this description in the X350 Workshop US002 and so am a little surprised that fuel, evap and O2s contribute to the system. I can say that my air pump cycles on at startup and given the warm morning temps here in the Sonoran desert, the pump remains on for only 35 seconds and cycles off at the same time high idle drops.
System used for a period of time each
time the engine is started, unless
certain temperature criteria are met.
Pumps air directly into the exhaust
system which generates extra heat and
reduces the time taken for the catalytic
converters to reach operating
temperature
temperature
I re-read your post see you changed the vacuum switching solenoid and not the vacuum operated diverter valve C2C32933. Bummer: I ordered and installed a new diverter valve when I installed the new serpentine belt and rad hoses... and after clearing DTC's, the P0414 re-appeared. I ordered the switching solenoid XR855179 and will swap that out next week-end.
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
