2007 STR Stalling
I had the same problem with my 06 STR which occurred about 4/5 times a year. Always when driving at walking pace (usually in traffic jams) and always when the car was fully warmed up. Sometimes it didn't actually stall, but you could see the rev counter dip very low before it "caught".
Seemed to go away (keeping fingers crossed, has been about 12 months) when I had my brake servo replaced (which had failed completely - was obvious when I had a loan car one day while mine was in for a new header tank). I'm guessing it was causing a vacuum leak.
Pending codes will appear and disappear, and of course no MIL, if it's intermittent but would be worth reading. If you can catch it, fuel trims in normal use as a baseline compared to when it occurs may tell you what is faulty but really intermittent things are tough. It can be anything from a chafing harness to a split pipe to a sticking valve.
Chafing harness can be found by wiggle test if you're lucky, but there's little wiggle room on an STR.
SoCalJagS
09-27-2015 10:20 AM
